Hallo,
I need to convert the coordiante of the sketch point to assembly coordiante.
I tried this macro to convert but the result in wrong, the correct result are the coordiante in the lower of frame of SolidWorks (see the image)
The part in the assembly is traslate in X axis of 100 mm about, so the assembly origin and the part origin insn't the same.
The macro return the point coordinate reference to the part(model) not the conversion of the assembly coordinate.
have you any idea how to fix it?
Thanks a lot
Roberto
' Preconditions:
' (1) Part, assembly or drawing is open.
' (2) If a part or assembly, then a sketch is being edited.
' (3) If a part or assembly, then an entity is selected in
' the sketch.
' (4) If a drawing, then an entity is selected.
' Postconditions: None
' NOTES:
' (1) If the sketch is a 3D sketch, then the selected sketch
' point is automatically in model coordinates.
' (2) If the sketch is a 3D sketch, then its transform is the
' unit transform.
Option Explicit
Public Function GetModelCoordinates(swApp As SldWorks.SldWorks, swSketch As SldWorks.Sketch, vPtArr As Variant) As Variant
Dim swMathPt As SldWorks.MathPoint
Dim swMathUtil As SldWorks.MathUtility
Dim swMathTrans As SldWorks.MathTransform
Set swMathUtil = swApp.GetMathUtility
Set swMathPt = swMathUtil.CreatePoint(vPtArr)
' Is a unit transform if 3D sketch; for example, selected sketch
' point is automatically in model space
Set swMathTrans = swSketch.ModelToSketchTransform
Set swMathTrans = swMathTrans.Inverse
Set swMathPt = swMathPt.MultiplyTransform(swMathTrans)
GetModelCoordinates = swMathPt.ArrayData
End Function
Sub main()
Dim swSelMgr As SldWorks.SelectionMgr
Dim swSketch As SldWorks.Sketch
Dim vSketchSelPt As Variant
Dim vModelSelPt As Variant
Dim i As Long
Set swModel = swApp.ActiveDoc
Set swSelMgr = swModel.SelectionManager
Set swSketch = swModel.GetActiveSketch2
vSketchSelPt = swSelMgr.GetSelectionPointInSketchSpace(1)
vModelSelPt = GetModelCoordinates(swApp, swSketch, vSketchSelPt)
Debug.Print "File = " & swModel.GetPathName
Debug.Print " Is3D sketch = " & swSketch.Is3D
Debug.Print " SelPt (sketch space) = (" & vSketchSelPt(0) * 1000# & ", " & vSketchSelPt(1) * 1000# & ", " & vSketchSelPt(2) * 1000# & ") mm"
Debug.Print " SelPt (model space) = (" & vModelSelPt(0) * 1000# & ", " & vModelSelPt(1) * 1000# & ", " & vModelSelPt(2) * 1000# & ") mm"
End Sub
Result in the immediate window
Is3D sketch = Falso
SelPt (sketch space) = (138, 283.85, 0) mm
SelPt (model space) = (138, 283.85, 6.81797779247439) mm
I need:
X-19.5 Y283.85 Z 6.8179
SolidworksApi macros
