Help!!! After PC "crash", EPDM Vault is not recognizable!
Hello guys!
As shown, luck is not in my side for a period now, and i'd like a help here!
At my work's pc, we have 2 hard disks, 1 ssd (which has our OS - Win7 and the installation folders etc etc) and a regular disk which we have our EPDM files, vaults, etc.
So, the previous Tuesday SSD disk, just failed to boot. "Hardware failure" was the technician's diagnosis. Every installation folders losst, but EPDM vaults, parts, etc are still in the other harddisk.
After SSD drive replacement, Win7 installation etc, I  reinstalled SW, and EPDM also, but the provlem is that though the vault can be recognised from the pc, and the EPDM, i cannot open it.
Note: before EPDM installation, my vault is recognised as a regular folder with subfolders and files, with their submitted filenames etc, but when i install EPDM, the folder gets the "blue sphere" icon, but it cannot be opened, since the message I receive is "No database is connected to this view". The only "rightclick" option i have, is "Delete File Vault View".
Inside EPDM administration, I can create a vault, and make changes to datacards etc (even if i lost my variables and BOMs - I will fix it again).
Is there any idea, how can I'll be able to recognise again the vault, and be able to work again?
Thanks in advance!
Answers 4
EG
EG 2012-05-14 Best Answer
The blue color is because the the is user/vault is off-line.
Push :
Tools-->work on line
to get back to online-status.
RT
RT 2012-05-14
What option are you getting when you RMB on your vault in Administration.
1. If "Create Local View" is not in the options then click "Explore",were does it take you?   Desktop?
2. Is it the EPDM Server we'r talking about here ?
3. A Clean Uninstall (Registry remove) after deleting the view will fix the prob?.
Regards
Ravi T
JG
JG 2012-05-14
Hello Emmanouel,
Please don't just try things for the sake of seeing if it works - Contact your VAR, explain to them what happened and let them help you re-connect to the server.
Do not delete the fie vault view if you have files checked out. The file vault view has a unique ID which is referenced by the checked out files.
Some things your VAR will need to know:
- Was SQL Server, EPDM Database Server, EPDM Archive Server and Archive location all located on the good drive?
- When you installed the archive server, did you change the archive file location (root folder) or did you accept the default
Once again, please allow your VAR to assist to prevent further loss.
Best Regards,
Joy
SF
SF 2012-05-14
No, i do not mean that. TY anyway!
