GTOL frame in design library note error when inserted
I am trying to add a note which includes a GTOL frame to our design library to make inserting standard notes more efficient.  I dont have any trouble adding the note to the design library, but when I go to insert it into another drawing the GTOL frame is replaced with "#error: broken link" (see attached image).  The note will insert properly to the original drawing it was saved out of, but for any other drawing it comes in with the broken link error.
Has anyone else experienced this issue?  Is this a bug or am I doing something wrong?
Any help would be much appreciated.
Answers 2
GS
GS 2013-10-02 Best Answer
Welcome to the forum.  I don't use GTOL notes, so I don't know I can help, but it's been a while since you posted so I'll give it a shot.  If no one else comes up with a better suggestion you might try saving that note in your Note Styles instead of in your Design Library.  At one time I saved notes in the Design Library also, but switched to Styles instead.  It just seemed to work better, and if you have more than one drawing template you can save notes appropriate to each template.
comment imagecomment image
SF
SF 2013-10-03
Thanks Glenn.  Yeah, saving the notes as styles in my template doesn't break the links.  It doesn't give me the exact functionality I was looking for, but it may do for now.  Upon further digging, I found there's an open SPR on this, so at least I'm not the only one having troubles.
And since this is starting to sound like a bug, I'm not expecting any better solutions/workarounds so I'll give you the 'correct answer'.
