Getting Configuration Specific Description Instead of Default Part Description
As the title says, I have a macro that, among other things, gets the description for the part. The only problem is that sometimes one of the parts will have a different description under one of the referenced configurations tab than the one that appears on the default tab. The macro is getting the default part description when I would like it to get the desciption that is under the referenced configuration tab.
Here is the function that is currently getting me the descriptions:
<p> Private Function GetCustomProperty(myComp As IComponent2, myProp As String) As String</p><p>    Dim myDoc As ModelDoc2</p><p>    Dim sa As Variant</p><p>    Dim i As Integer</p><p>    Dim myVal As String</p><p>    Dim myValOut As String</p><p>    Dim myMgr As ICustomPropertyManager</p><p>    Dim retB As Boolean</p><p></p><p>    Set myDoc = myComp.GetModelDoc2</p><p>    If myDoc Is Nothing Then Exit Function 'This will happen if you load your assembly lightweight</p><p>    Set myMgr = myDoc.Extension.CustomPropertyManager("")</p><p>    GetCustomProperty = ""</p><p>    sa = myMgr.GetNames</p><p>    If IsEmpty(sa) Then Exit Function</p><p>    For i = 0 To UBound(sa)</p><p>        If sa(i) = myProp Then</p><p>            retB = myMgr.Get4(sa(i), False, myVal, myValOut)</p><p>             </p><p>            GetCustomProperty = myValOut</p><p>            Exit Function</p><p>        End If</p><p>    Next</p><p>End Function</p><p></p>
I can post more code if need be.
SolidworksApi macros
