Font Point size is defined as 1 POINT =1/72 INCH in the rest of the world. Solid Works seems to define it as 1/100 of an inch (not exactly). Can I change the point scale so when I choose 16 point it is not .16 high but instead .222?
I never noticed this. I always just use .125" for annotations and dimensions and .25" for titles...Never even noticed that discrepancy.
I'd guess that what you are asking for is not currently possible. You can submit it to your VAR and see if they can get you an SPR on this. Then post it back here.
Thanks all!
I have inherited a bunch of designs that have font on them because the parts are sent out for screen printing. The printers use Microsoft products or others that use font points....Of course I am now changing them to height and making it incumbent on the screen printer to do the conversion. FYI, I got a creepy feeling that perhaps AutoCAD created this new scale back in the eighties but they I checked and they do not use points anywhere I can find.
wow I hate them darn points, We have the choice to make them a dim, or use points, of course the boss picks out points from EXCEL or Word, and then I need to match them to SolidWorks. Ansi standards determines what size text should be on drawings for notes and dimensions. The only place I would see varying that is for data entered in the title-block.
Interesting. I never noticed this before. I certainly agree that if they include "points" they should be accurate. However, like Matt, I have always used real measurement values to define font sizes. I really see no reason to include "points" at all as a font size option.
I tested this out and found 12pt in SolidWorks is the same as it is in Word. I read somewhere that every font contains empty space and so that may account for 1/72 vs 1/100 discrepancy. I'm not in the least an expert in fonts and sizes, but I don't believe there's a 28% difference in heights here. I suggest not to specify text height using points in SolidWorks.
@TP how did you test out the 12pt in SolidWorks vs in Word out of curiosity? We are having a discrepancy between when someone creates a part marking based off of our drawing/model font size in SolidWorks. It does not occupy the same area on the physical parts as it did in our model.
Old thread but still not resolved. Just tried it. If I use Point size as the units and put 9pt, the shaded equivalent fractional size shows 1/8 (and I put a note in my drawing in that size it comes in as 9pt) but then if I do a new note and set control to be fractional instead of points and call it 1/8, the shaded equivalent point size shows 12 (speaking to an approximate 1/100, not the standard 1/72) and drop that in, it is definitely larger than the 9pt. When using the Point system, it rounds to the nearest fractional, so even 10pt, 11pt, 12pt, 13pt, etc. all show as 1/8, but if you set the control to fractional, it sits on 12pt. Definitely still a problem.
