I need to create a rule to suppress/unsuppress a feature in a part which has many configurations. I want the feature to be suppressed in all other configuration and it should be unsuppressed in a selected configuration only if the rule condition is achieved. Is there any way to do this in solid works modelling?
In other words i want to create a rule that applies to only a specific configuration.@
SolidworksConfigurations/design Tables
Have you tried DriveWorks Express?
Thank you all. I found out the solution
How to use equations in SOLIDWORKS (basics + advanced)
Yes, All equations can work for only chosen configurations. When you lick RMB You have access fot this options
I already used equations. But the feature unsuppress in other configurations also if the conditions met. I want it only in one configuration. Is there any way to make equations applicable to specific configurations only.
One word: Equations
I cannot use express here. The final model need to be adjusted by basic sketch editing type. currently the model is controlled by a master sketch which drives all the components.
