I created a DXF file that we would use to water jet cut a panel and then a separate file to laser etch some text to the panel. The cut file for the panel stayed dimensionally correct (1.07 x 1.02) but the file for the laser etching would change the height only (from 1.02 to .98). Does anyone have an idea of what I can do to keep this from happening in the future?
I do this process all the time but this is the first file with so much text information. I am guessing that there is so much text info that it is getting confused somehow. Attached are some PDF images of the files once they are converted to DXF.
SolidworksImport export
Wes,
Its difficult to tell what is going on from your screenshots. Can you post the SolidWorks file and the DXF files?
I edited the post to contain zipped files of the DXFs.
Can you post the SolidWorks file as well?
Should be up as well.
I do see the discrepancy but I don't know whats causing it.
The sketch is still open when I open your SolidWorks file. I suggest closing the sketch and exporting new DXF files to see if there is still a problem.
Also, the text indicates it is using a feature, (maybe a line or curve?), that is no longer present. I'm not sure if that is an issue though. You could try to resolve that and then export your DXF files again to see if the problem persists.
Otherwise I don't have a clue.
Yes, I place the text by drawing a line and placing the text on that line. Once the text is in place, I delete the line so it is not a part of the file. Like I said, I have done this numerous times and have never had an issue.
Wes, when I opened your SolidWorks file, the view was not normal to the sketch (slightly tilted). Press CTRL+1 or CTRL+8 to get it normal with the front plane, and perhaps that will resolve your issue?
Normally when I create DXF files, I do it through saving a sheet on a .SLDDRW file, so I am not quite sure in what ways DXF saving from the part might behave differently.
It looks like that was the issue. I reset the view so it was normal to the plane and I came up with the correct dimension once converted to the DXF. I am still not sure how I got it tilted but that seemed to solve the issue. I will have to be sure to pay attention to this detail in the future.
Do you think If I went your suggested route of the .slddrw file that I cold eliminate this issue in the future?
Saving from a .SLDDRW file would likely eliminate that issue, because typically you will only place normal orthographic views. However, for DXF saving, you have to be sure that you are saving at a 1:1 scale. We have a drawing template at my job that has a second "DXF" sheet that has the sheet scale set to 1:1. Side note: to set a sheet scale, click on the sheet, and go to Edit > Properties; Scale is toward the top left.
If for some reason you don't normally use .SLDDRW files, it might be slightly inconvenient to have to go through this extra step. But if you DO use .SLDDRW files, I would definitely consider adding a 1:1 DXF sheet to whatever drawing template you use.
