Hi There,
I am working on a company where in we use solidworks in marketing purposes, for automated quotations of product orders. specifically medical, food and commercial storage equipments. We use a 3rd party tool that uses Solidworks in automating different configurations of assemblies using macro. with that, it can also generate PDF approval drawings without even using solidworks manually.. all are automated using Macro.. One problem that I recently encounter is that when the drawing is generated and when the scale is changed, the views somehow moved. sometimes it moved outside the drawing frame, so the PDF approval drawing created is Wrong.. does anyone know how to prevent this? i already tried "Lock View Position" but it still moved when i changed the scale, but it cannot be dragged.
When you change the dwg scale its going to move try changing the view scale.
Hi Tony,
Thanks for quick the reply. The thing is, it is an Approval drawing so in the drawing frame we specify the scale on one of the boxes, and as you know it is linked to the “drawing scale”. So we have to set the views to “use sheet scale”.
Is there any other way?
Also, I just tried changing the scale by using “Use Custom Scale” on the view options, but it still moved.
I only see this behavior when the model geometry is not centered on the origin of the model - the origin stays put, and the geometry scales about it, making it appear to move.
Hi Jeremy,
Thanks for the reply. I tried checking what you meant and moved the assembly in a way that the origin is in the center, but the view still moved the same way as when the origin is not on the center. Again, thanks for the reply.
I'm running into this as well. when i change the scale of the drawing i have to re-align my views. Seems to mostly occur when i have a formed view projected from a flat pattern.
Try selecting the section view and navigate to "alignment" then select break alignment. It seems like the view is not really moving, but expadning/contracting based on being aligned with some point on the parent view.
Still happening in 2018.... Fix is RMB on the view out of alignment, align horizontal or vertical by center depending on what you need.
