I am using solidworks for a year almost and i just got this problem and i have no idea why it is happening since i did nothing wrong... ANyway i have drag and drop failed error. It happens when i create an assembly that has flanges and insert it into new assembly. So as long i have no flanges in my top level assembly i am able to get drag and drop. But if my assembly has sub-assemblies with the flanges, drag and drop fails. It also fails even if i have some of the subassemblie opened in the back, but not inserted into top level assembly yet..it also will not allow me to open the library part...
What am i doing wrong here....?
SolidworksRouting
Can you attach the files here?
Attached is sub-assembly in question
I had my part file names the same. That was the reason. It was in front of me the whole time and i was not seeing it...
In Solidworks "Routing" add-in, i need drag into 5 same connector (3pin) female.sldprt, it still appears "Drag and Drop failed".
But i need drag into the same file in design library, how to resolve it?
Li,
Do you already have the same connector on the assembly? If so, it might be a same name but different file.
-Jose
Li,
You can have unlimited number of instances of one part in your assembly. But "drag and drop failed" issue comes up when you have two parts of the same name. For example:
In your library, you have part for elbow in plastic and separate part for elbow in steel. You have folder "plastic" and folder "steel", and both of the parts are named "elbow". That is the problem.
it does not matter that the parts are in different folders, they cannot have the same filename - elbow.sldprt
Was that helpful?
