I wrote a code around a logic by which we can dissolve sub-assemblies inside another sub-assembly. I was not able to achieve the objective of dissolving. I went through one of the author's code (Keith Rice) but still I am a bit confused.
Here is my code, can some kindly help me out?
Dim swAssem As SldWorks.AssemblyDoc
Dim swFeat As SldWorks.Feature
Dim swComp As SldWorks.Component2
Dim swRootComp As SldWorks.Component2
Dim swConfMgr As SldWorks.ConfigurationManager
Dim swConf As SldWorks.Configuration
Sub main()
Set Part = New Collection
Set swModel = swApp.ActiveDoc
Set swAssem = swModel
Set swFeat = swModel.FirstFeature
Set swConfMgr = swModel.ConfigurationManager
Set swConf = swConfMgr.ActiveConfiguration
Set swRootComp = swConf.GetRootComponent3(True)
While Not swFeat Is Nothing
If swFeat.GetTypeName2 = "Reference" Then
Set swComp = swFeat.GetSpecificFeature2
If UCase(Right(swComp.GetPathName, 3)) = "ASM" Then
MsgBox "Name : " & swComp.Name2
Call Dissolve(swComp)
End If
End If
Set swFeat = swFeat.GetNextFeature
Wend
End Sub
Sub Dissolve(prt As SldWorks.Component2)
Dim Children As Variant
Dim ChildComp As Component2
Dim Aparts As Integer
Dim Pparts As Integer
Aparts = 0
Pparts = 0
Dim swcompModel As SldWorks.ModelDoc2
Dim swcompAssy As SldWorks.AssemblyDoc
Dim test As Boolean
Children = prt.GetChildren
For i = 0 To UBound(Children)
Set ChildComp = Children(i)
If UCase(Right(ChildComp.GetPathName, 3)) = "ASM" Then
MsgBox "Name 2 :" & ChildComp.Name2
Aparts = Aparts + 1
Call Dissolve(ChildComp)
Else
Pparts = Pparts + 1
End If
Next i
If Aparts = 0 Then
Set swcompModel = prt.GetModelDoc2
Set swcompAssy = swcompModel
prt.Select4 False, Nothing, False
test = swcompAssy.DissolveSubAssembly
End If
End Sub
Thank you,
Arvind
SolidworksApi macros
