When I run a simulation in SOLIDWORKS Simulation, I notice an issue with the displacement results related to material stiffness.
If I assign a soft material with low hardness / low stiffness, the resulting displacement is about 6 mm. However, when I change the material to a much stiffer one, the displacement changes very little and does not seem consistent with real-life behavior.
I observe this problem in all of my tests, not just in a specific model. The loads, fixtures, and mesh remain the same — only the material properties are changed.
I would expect a significantly smaller displacement when using a stiffer material, but that is not what the results show.
Am I missing something related to material properties, boundary conditions, solver settings, or nonlinear effects?
Any guidance would be appreciated.
I would start by looking at some Validation Examples which have a known, formula/equation-based theoretical solution. For example the "Bending of a Solid Beam" SOLIDWORKS Simulation Static Verification Problem (see image below). After you correlate SOLIDWORKS Simulation results to theoretical results, copy the study and change the material to build confidence.
If SOLIDWORKS Simulation is new to you, I also recommend the following Learning Paths on MySolidWorks:
SOLIDWORKS Simulation: Nonlinear
tree materials - tree very different Elastic modulus values - tree different displacements.
