Hi
For starters, I know just about enough VBA and SW API's that's I'm very dangerous to file integrity. I wanted to change variable name in our library part files and wrote this macro that copies value from Config Specific Properties, creates new variable in the same property and pastes this copied value in there. It seems that my program works, but it takes very long time to go through all the custom properties. Is this okey?
Macro is here:
Dim
Dim swModel As ModelDoc2
Dim swModelDocExt As ModelDocExtension
Dim swCustProp As CustomPropertyManager
Dim val As String
Dim valout As String
Dim bool As Boolean
Dim fieldname As String
Dim FieldName1 As String
Dim FieldType As Integer
Dim FieldValue As String
Dim OverwriteExisting As Integer
Dim value1 As Integer
Dim i As Integer
Dim vConfNameArr As Variant
Sub main()
Set swModel = swApp.ActiveDoc
fieldname = "nimetus"
vConfNameArr = swModel.GetConfigurationNames
For i = 0 To UBound(vConfNameArr)
Set swModelDocExt = swModel.Extension
Set swCustProp = swModelDocExt.CustomPropertyManager("")
sConfigName = vConfNameArr(i)
'Set cpm3 = swModel.Extension.CustomPropertyManager(sConfigName)
'bool = swCustProp.Get4(fieldname, False, val, valout)
bool = swModel.Extension.CustomPropertyManager(vConfNameArr(i)).Get4("nimetus", False, val, valout)
FieldName1 = "Description"
FieldType = 30
FieldValue = valout
value1 = swModel.AddCustomInfo3(vConfNameArr(i), "Description", FieldType, valout)
Next i
End Sub
Is everything okey with my code?
Best regards!
SolidworksApi/macros
