We rarely need to design or build welded structures, so though I have used a couple of times the welding tools I am not really familiar with them.
So I designed a rather ugly support table and I would like to build it from bare sheet metal (not profiles), and I need the individual dxf parts to cut them in our laser table and then bend them before actually welding them.
Is it possible ? May I split the welding structure and turn it into an assembly ?
Use Sheet Metal from the start and you will not have any issues.
You can save out the bodies externally to create an assembly by right clicking on the bodies folder in the feature tree and selecting save bodies, but you wouldn't be able to flatten it using the sheet metal flatten. If you have SOLIDWORKS Premium you might be able to do something with surface flatten to generate the flat DXF
Thanks ! I will do as John advises.
You can convert each piece of angle to sheet metal using the Convert to Sheet Metal command (for the frame, you need only do two, long and short, and then mirror).
Since you must convert a member one body at a time, SW doesn't have the chance to maintain the common corners for you.
And since sheet metal requires normalcy, the corners overlap and will require additional cuts to remove the interference.
Moral of this story: Do as Mr. Sitek suggested.
