Hi Everyone,
The company I work for receives vast amounts of 3D CAD Data via IGS files. These IGS files normally are parts, which can be put together in an assembly and form a component together. In order to reduce the manual labour, I am now programming a macro which converts all IGS files in it's folder to SLDPRT's, starts an assy, inserts the new SLDPRT, then transforms the origin so the origin of the part lines up with the origin of the assembly, repeats this proces for all IGS files in it's folder and saves and closes all documents. So far so good. All of this is working.
But here comes the problem;
It only fixes the first component which is inserted in the assy. The second (and all latter ones for that matter) stay floating. I have looked into the fixcomponent Method but I can't seem to get it to work properly. Who can help me out?
PS: The code is still sloppy, I have quite some experience in Excel VBA, but these are my first endeauvours in SW, so be kind
The code I have so far:
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim longstatus As Long
Dim longwarnings As Long
Dim sFileName As String
Dim Path As String
Dim partFileName As String
Dim FixFileName As String
Dim openDocs As Variant
Dim currentModel As Variant
Dim swPartDoc As PartDoc
Dim swAssemblyDoc As AssemblyDoc
Dim swComp As Component2
Dim swMathUtil As SldWorks.MathUtility
Dim swXform As SldWorks.MathTransform
Sub main()
Set swApp = _
Application.SldWorks
Path = Left(swApp.GetCurrentMacroPathName(), InStrRev(swApp.GetCurrentMacroPathName(), "\\"))
sFileName = Dir(Path & "*.igs")
Set Part = swApp.NewDocument("H:\\SolidWorks\\Common Data\\VdB Assembly.asmdot", 0, 0, 0)
swApp.ActivateDoc2 "Assem1", False, longstatus
longstatus = Part.SaveAs3(Path + "Assy.SLDASM", 0, 2)
Do Until sFileName = ""
boolstatus = swApp.LoadFile2(Path + sFileName, "r")
Set Part = swApp.ActiveDoc
Dim myModelView As Object
Set myModelView = Part.ActiveView
myModelView.FrameState = swWindowState_e.swWindowMaximized
longstatus = Part.ImportDiagnosis(True, False, True, 0)
Part.ClearSelection2 True
longstatus = Part.SaveAs3(Path + Part.GetTitle + ".SLDPRT", 0, 0)
openDocs = swApp.GetDocuments()
For Each currentModel In openDocs
If (currentModel.GetType = swDocumentTypes_e.swDocASSEMBLY) Then
Set swAssemblyDoc = currentModel
End If
If (currentModel.GetType = swDocumentTypes_e.swDocPART) Then
Set swPartDoc = currentModel
partFileName = swPartDoc.GetPathName()
End If
Next
Set swMathUtil = swApp.GetMathUtility
Set swXform = swMathUtil.CreateTransform(Nothing)
swComp.Transform2 = swXform
swAssemblyDoc.EditRebuild3
longstatus = swAssemblyDoc.SaveAs3(Path + "Assy.SLDASM", 0, 2)
swApp.CloseDoc swPartDoc.GetTitle
sFileName = Dir
Loop
swApp.CloseAllDocuments (True)
End Sub
SolidworksApi macros
