Component Configuration Drop Down in Design Table
This is likely a simple answer, but every time I search, I get 10,000 responses for part configurations, and nothing for assembly design tables.
I need to add a component to an assembly design table. With the table open in another window, I double-click on the component, and I get a column with the \\\$state in the header.
I don't want the \\\$state; the component is there all the time. I want \\\$configuration. I can type in \\\$configuration, but when I do, I do NOT get the drop down box with the configurations for the component. The other columns in the table I'm working in have those drop downs, and the table "enable drop down lists" is checked.
First, are there any decent documents out there for assembly design tables? A couple of simple videos I saw focused on mate values rather than component values, or typed everything in by hand. That's possible, but not practical for the multiple component configurations I have.
SolidworksConfigurations/design Tables
Answers 3
NV
NV 2021-04-09 Best Answer
You should be able to RMB and select configure component in the assembly.
Otherwise use $configuration@part. I think they may have to be entered manually with that method.
NV
NV 2021-04-09
Found a work around.
RMB and configure the component manually using the drop-downs.
After, insert a new design table from blank. You should now see $CONFIG@PART as an option to add to the table.
This will then enable the cell to read the parts configuration options as an automated drop-down.
SJ
SJ 2021-04-09
I can do a rmb and configure manually; no problem.
My question is how to get the drop down box with the component configurations in the design table. Manually typing in the $configuration doesn't do it.
I could delete the entire table and then add a new one from scratch, but that's a lousy workaround.
