I am at my wits end on this one. I am a new user to solidworks so I am unaware of advanced surfacing techniques. I am trying to create a curved surface for the bottom of a skateboard I am designing. I have tried a few different techniques like boundary surfaces and freeforms with no luck. I need something to make the curvature smooth without messing up the edges. Could somebody please guide me towards what techniques I need to use to accomplish this? Thank You.
Attached is an example of what I am trying to accomplish and a few files of my board
SolidworksSurfacing
Hi Tim,
Start by building only half of it and in the end, mirror it. - this will make your problem easier.
Mark
Hey Mark,
Thanks for the advice. I was able to solve the problem and achieve what I was looking for with a surface fill and plenty of guide curves. Only problem now is when I go to combine the new surface solid with the original solid I get an error saying "the operation could not be completed due to geometric conditions".
I also noticed that my fill has some gaps although they are very small (<.001") this could be preventing the combine function. Any advice towards that?
I uploaded the newest model of my board for reference.
Tim,.. from what I can view/see/read... the shared/same surface and edges of the two bodies is giving you problem with the combine... so, delete the surface on both bodies and knit the top/btm to form a solid.
I pretty much had to remodel the enitre part into only surfaces but that solution worked. Thank you very much
kewl,.. surfaces are your friend.. your board is better off created with them! cheers!
Here is the part with a little tweak to make it a solid. Tom
