combine problem with variable fillets feature
Dear All,
            I have a problem most frequently combine a parts with variable fillets feature. normally I want use variable fillets in my design, also need to separate body's on  fillets region using cut with surface / subtract/revolve cut ex... to create multi body parts for use to any feature(patterning to isolated body ex..). some time  difficult to separate as a multi body. (operation failed due to geometric condition )  if successfully separate as a multi body, but try to again combine some time to SW pop-up same geometric condition or zero thickness geometry. so how i fix this problem ? any procedure to identified what's wrong? as a example I attached part file herewith.
SolidworksParts And Features
Answers 8
CJ
CJ 2011-08-25 Best Answer
Dear All,
              I'm waiting your valuable advices or comments above mentioned issue.
BR
Chandana
SF
SF 2011-09-02
Chandana,
I don't have time to look at your model and couldn't open it if I did, being on 2010, but I can tell you that lots of people have trouble with the good old "geometric condition". SW is not fond of faces that are coincident. If at all possible, it is better to have deliberate interferences when you try to combine bodies. This makes it very hard to do the split, modify, combine type of work you are doing, even though it may be the only way to get what you want. Variable radii are also one of the trickier features to deal with, so you are really living on the bleeding edge. The classic advice is to save the fillets till last, but that is often not possible.
Sorry I can't be more helpful.
Jerry Steiger
CJ
CJ 2011-09-02
Dear Jerry,
                 thanks a lot for your attention my issue, however it is more difficult to do but I'm doing trial & error method. changing variable radii then cut with surface feature. but SW  not guiding to how to solve that without "geometric condition". so very difficult to identified what's wrong.
BR
chandana
SM
SM 2011-09-02
Chandana,
I can't put my hands on it for the moment, but I am pretty sure that you cannot
fillet between different solid bodies using the fillet command.  I think you are better
off creating a variable section swept surface to do this.  Then mesh the surfaces together.
CC
CC 2011-09-02
Chandana,
It is difficult to determine the best method for what you are looking for, because I can't tell what your end goal is. I can suggest that you work with surfacing tools instead of solid tools. Then just knit them together in the end to make a solid body. This will remove the problems you are seeing with trying to cut and combine solid bodies.
In this example I would just select each half of the surfaces to make surface bodies, then modify them as required. Don't try and cut them as solid bodies.
Does the attached model create what you are looking for?
CJ
CJ 2011-09-07
Charles,
         If we think, anyhow we split 2 bodies of our example using cut or subtract or any suitable feature. but why we cant again combine to single body? (in attachment we can't combine both Body-Move/Copy1[2] +Surface-Knit2 as single body). this is my main issue. because I need to separate body with fillets, then need to repeat as pattern it and also combine all iso bodies with another body. just think as example is tire lug, we create single lug with fillets, then separate with fillets. again pattern around revoleve  axis. finally need combine with all lugs with revolve part to create tire as single tire part.
SF
SF 2011-09-26
Chandana,
Fillets and patterns often have problems. You may need to pattern your bodies first, unite them with the other body, and then add the fillets where the bodies join.
Jerry Steiger
LB
LB 2011-09-26
the issue is that the fillets create a sharp edge which is the same issue we have when you try to cut a circular hole tagent to an edge....no material. you need to thicken the bottom face of the lug so you have material to combine together. and it works!!!!
comment imagecomment image
