clean SW intall on resinstalled system yields double-click and redraw issues
My system had a hiccup so I have reinstalled windows 7 and all software on top, including solidworks 2013.
It basically works, but there are two weird behaviors it didn't have before, and I've not been able to find any related options to turn them off.
1. If I click on a solid, it behaves like I've double clicked and shows me the dimensions in the generating sketch.   Oddly, nothing else behaves like its been double clicked, and double click seems to work perfectly normally.   This is actually quite distracting and annoying - thoughts on what option would turn this off?
2. Under certain conditions, the part or sketch moves, get reoriented, as though some kind of auto-zoom or auto-rotate had been executed.   It didn't used to do this.  (Example - sketch some simple shape like a square, then do a feature>rotate, the sketch will be rotated around at an odd angle for no apparent reason.   You can put it back, but why did it move by itself?)
SolidworksAdministration
Answers 5
KL
KL 2013-11-25 Best Answer
1)  Sounds like you have Instant 3D enabled.
2) Does the sketch actually move or does the plane just appear to rotate?
Where is the "features>rotate" command you mentioned?
BW
BW 2013-11-25
re: #`1 - good call - turning that off solved that weirdness.   Thank You.
re: #2 - I misidentified - it would be features>revolved boss/base (icon that looks like 1/2 of a donut.)
In answer to your question (I hope):
Pick a plane (say Right Plane)
Make a sketch on this plane
Close the sketch
Do a "features>revolved boss/base"
The sketch will rotate around the Y axis, and move a little bit up and to the left.
Doing an extrude (starting from the beginning sketch) will do the same.
One sees this moving around in other places too.
I would swear it didn't do this before the reinstall.   But I've not yet found the option to turn off to fix this #2 problem.
thx
bmw
KL
KL 2013-11-25
Can you post a sample part showing the #2 problem.
Is your sketch fully defined before doing the revolve?
Do you have multiple centrelines or construction lines in the sketch?
MK
MK 2013-11-25
I believe #2 is normal behavior, and can't be changed.  The view rotates to a trimetric view upon feature creation, automatically.  Looks like it does it if you are in what I would call a normal to view (front, right, top, etc.).
BW
BW 2013-11-27
OK, Kelvin Lamport's comment that "instant 3d" was turned on was 100% correct, and once I figured out what and where that was how to turn it on and off, that solved issue #1.
Mark Kaiser is pretty much right about #2, but there's a gotcha.   I got help from my reseller (I was able to post a video to them, couldn't figure out how to do that here) - BUT - "transitions" were on, which made things look weird - turning them off made things look "normal" AND yes, when you create a feature the part still gets rotated, but it's what I was used to.
AND AND
In solidCAM, when you have transitions on, it "moves the part" in awkward ways when you apply various solidCAM operations.   When I turned off transitions, solidCAM stopped moving the part at all when I did operations - so turning off transitions both made solidworks look normal and made solidcam behave.
Thank you both for your helpful replies.
