Trying to export a PCB to CircuitWorks. I have a coordinate system named CWX at both the board level and the top level. either works for getting the export coordinate system to match the desired coordinate system.
(SW 2014 on Windows 10).
It worked before on my old computer. Maybe a Windows 10 thing?
SolidworksCircuitworks
I know this is old but...did you check settings and see if "CWX" is defined as the coordinate system? The setting can be found under CircuitWorks->Options->Solidworks Export. From there you will see an option for use "zzz" as coordinate system. Mine has "CWX" in that field.
Thanks for the reply. Yes,I did check. Seems to work for components but not for the actual board.
