I've been running an internal, conjugate heat transfer simulation on a copper cylinder. my fluid is water at 3 atm static pressure at the inlet and 1 atm (environment) at the outlet. the copper cylinder is set as a constant heat source of 100 kW. my outer wall is set to a heat transfer coefficient of ~5kW/m^2 when I create the flow trajectory for water, I get its average temp of 23 deg c, which makes sense. when I create a surface plot of the copper surface in the fluid subdomain I get that the water temp there is over 100 in a few non negligible regions. Does this mean that the water there will boil and cause complications to my tube, despite the average temp remaining 23 deg?
SolidworksFlow Simulation
This is a Steady State simulation
Do these "hot spots" look physically reasonable, or could it be a computational error due to a bad mesh at the area? Generally speaking water conducts heat well and if your heat generation is equally spread out, then hot spots don't make sense. Unless you have some complicated geometry that is causing stagnation pools or something...
They are physically reasonable, the tube has a spiral path along the middle and the hot spots occur where the water flows less, at pi radians from the spiral intake. The water flows into the spiral but stagnates around the area furthest from this intake. Geometrical advice aside, I would like to reiterate- does the resulting fluid temperature of 100+ degrees c on the surface of the tube mean that the water there may boil, bubble and affect pressure, or is it a zero thickness result and therefore negligible? average water temp is given at 3.5 degrees hotter than inlet.
I believe that the software should warn you if it finds that you are getting too near the phase change boundary, but I'm not 100% sure. You could try re-running the analysis with a higher heat transfer rate and seeing what happens.
Indeed under the calculated pressure the water does not vaporize, but have you seen software warn when phase change is imminent?
