Change sheet format for specific sheet per file -> Help
Hi everyone,
I'm going to attach some code that may be beneficial. What I want to do is change the format of every sheet that has the word "Packaging" in the sheet name from one sheet format to another in x amount of files per specific folder. In essence I have a folder for all of these drawings and I would like to change all of the packaging specs of each drawing in that folder from 8-1/2"x11" to 11"x17" and have everything scale appropriately. I doubt it will work that well so instead I've made a seperate sheet format that I would like to replace all of those sheets with "Packaging" in their sheet name. I know this is possible but my experience with VBA is very very limited. Heres what I have thus far:
Option Explicit
Dim swModel As ModelDoc2
Dim swFilename As String
Dim swDraw As SldWorks.DrawingDoc
Dim swSheet As SldWorks.Sheet
Dim bRet As Boolean
Dim Path As String
Dim nErrors As Long
Dim nWarnings As Long
Dim DocName As String
Dim i As Long
Dim vSheetName As Variant
Public Const sTemplatePath As String = "A:\\Engineering_Files\\SW Backup Files\\Settings"
Sub main()
    Path = "A:\\Engineering_Files\\Current Product 2011\\Drawings\\1 Sq Picket"
    swFilename = Dir(Path & "*.SLDDRW")
    Do Until swFilename = ""
    Set swModel = swApp.OpenDoc6(Path + swFilename, swDocDRAWING, swOpenDocOptions_Silent, "", nErrors, nWarnings)
    Set swModel = swApp.ActiveDoc
    Set swDraw = swModel
    vSheetName = swDraw.GetSheetNames
    For i = 0 To UBound(vSheetName)
       bRet = swDraw.ActivateSheet(vSheetName(i))
'Put the required sheet format name
       swDraw.SetupSheet4 vSheetName(i), swDwgPaperCsize, 12, 1, 1, False, sTemplatePath & "westech packaging-11x17.slddrt", 0#, 0#, "Default"
        swModel.ViewZoomtofit2
    Next i
' Switch back to first sheet and change format
    bRet = swDraw.ActivateSheet(vSheetName(0))
    swDraw.SetupSheet4 vSheetName(0), swDwgPaperCsize, 12, 1, 1, False, sTemplatePath & "westech packaging-11x17.slddrt", 0#, 0#, "Default"
    swModel.ForceRebuild3 (False)
    swModel.Save
'swApp.CloseDoc swModel.GetTitle
   Set swModel = Nothing
   swFilename = Dir
Loop
MsgBox "Make sure it worked!"
End Sub
SolidworksApi macros
Answers 0
