CFD - F1 Front Wing - How to add a moving wall ground plate?
Im trying to calculate the downforce produced by a front wing. Therefore i need to add a ground plate, to capture the ground effect, and set it as a moving wall with a velocity the same as the freestream velocity.
How do i go about doing this?
any help would be greatly appreciated.
Thanks
Alex
SolidworksFlow Simulation
Answers 4
CM
CM 2015-02-23 Best Answer
You will want to use a real wall boundary condition and add velocity.  I've got a simulation running so I can't open the dialog to verify the wording, but it's one of the standard boundary condition options.
SF
SF 2015-02-24
model the wall
apply moving wall
make sure to do some tests with a simple aero shape in 2d to see how many cells and how big the comp domain needs to be to properly capture drag and lift
SF
SF 2015-03-03
Thanks guys,  regarding the goal to calculate the force in the y direction. Am I right in saying i cant use the global goal as this will include the ground plate moving wall? Therefore I should use the surface goal?
SF
SF 2015-03-04
correct and correct
I would highly recommend doing some really simple tests like on a block just to get your head wrapped around everything
understand the sensitivity to mesh and comp domain size
and generally the results that you get from flow relative to physical/absolute values
