I have a component I wanted to mate. It does not want to move by a triad or the move tool. It says it is fully defined but has no constraints. Also, it is not fixed.
When I right click, it only says 'FIX'. There is no (f) prefix either. Why doesn't this thing move? I tried using the translate box option and that worked! WHY?
Can you attach file?
In the amount of this part in the assembly, it can restrict the assembly when you start a process or not. Did you check?
It sure looks like this is a possibility where the first item in the tree looks like it says "original..." which would lead me to conclude this referencing something else that is fixed.
Edit: Scratch that...that's "Origin" under the main planes. Carry on...
picture 2 we can see :
Did you make the part in assembly referencing other part?
Does other part referencing this part?
break all the "Ext.Ref" in your part.
Why are you using Move rather than assembly constraints?
Multi-body part?
Is this really an assembly (*.sldasm)?
How will that geometry be manufactured (appears to be invalid sheetmetal to me)?
