I'm following a youtube tutorial to practice my skills at solidworks. I'm trying to surface loft between two profiles using guide curves. I have a total of 4 guide curves but it won't let me use two of them, it only works with one or the other. I really need both. Can anyone help with this issue?
I've attached an image showing which two guide curves are the problem, I've also attached my solidworks file.
Solidworks: Panton chair - YouTube < This is the tutorial I'm following but it doesn't help with my problem. My email is oliver.j.sunderland@student.shu.ac.uk please get in touch if you think you can help.
Message was edited by: Oliver Sunderland I've added the updated model. PantonChair_V2
SolidworksEducator Student
If you can get the sketch 5 added to the sketch 2 it should work
Steve C
Well, that didn't work either. I'm busy at the moment, let me try again later
I moved the 3d sketch spline a bit , see image. You might want to fine tune the model before you take it further.
I agree with Ingvar Magnusson in that your splines need to be adjusted. I have also had things work out better by splitting the guide curves into separate sketches. What I see as the cause for the failure when applying both of you guide curves, was that it was causing a surface flow issue in SW. After adjusting the location of the same guide curve that Invar did, I too got the loft to use all of the guide curves.
Thanks Ingvar, I've done a bit of tweaking. I know the model's not perfect, but have you any ideas how I would get a smoother surface on the image attached?
I'm guessing it's to with the body that I've mirrored but I've been playing around with the model for a while and can't find a fix. Any thought's you've got would be a great help. I'm trying to attach my new solidworks model to this post in case you wanted to take a look but I'm not sure how to.
Thanks,
Oliver
