Can I use a global variable to define a reference plane's offset?
I want to define a reference plane offset from another plane.  I'd like to use the value of a global variable for the offset distance.  Have searched help, but found it to be no help on this question.  Can you help?  I'm using SW2010 (just installed the upgrade from SW2009).
Thanks,
Bill
SolidworksParts And Features
Answers 5
DG
DG 2010-06-05 Best Answer
After you have created the offset plane, double click on that and offset dimension will show up. Double click on that dimension and then you can use either link value or equation to set that dimension equals to the global variable already defined.
SF
SF 2010-06-08
Thanks, Deepak.  Just what I needed to know.  I spent a long time with "help" trying to figure that out.
MM
MM 2020-04-25
I have the same question and double clicking on the plane does not bring anything up. I think this may have changed in 2020, I also cannot reference a global variable distance in the feature tree. Is there any updated solution to this?
Kind regards
Michael Mullineux
GS
GS 2020-04-25
Michael Mullineux wrote:
Kind regards
Michael Mullineux
Do you have Instant 3d turned on?  If yes, then a single click on the plane in the tree instead of double-click should show the dimensions in the graphics area.
MM
MM 2020-04-26
Sorted, Thanks so much
