Can help with watercooling and overclocking
I offer my experience with watercooling and at a lesser degree overclocking (if I do not know I can find out,to a degree) for anyone that needs tips on parts or techniques. I like to try and give help back as I really do appreciate when people help me.I am a Networking Admin student here in Tucson at the local community college and at times I need a break fronm networking and enjoy working with programs as basic as the Adobe group and as complex as Solidworks. I will add Linux is not my speciality,but I can help a bit.
Best Regards
Daniel Rose
SolidworksAdministration
Answers 14
CC
CC 2011-07-28 Best Answer
Daniel,
I am working on a new "suggested system thread", and my last one got a few overclocking questions that I wasn't really able to answer with authority, so that would be great.
SF
SF 2011-07-28
Charles, I can help you as well (I am an AMD CPU type guy, but Intel or AMD's overclocking basics are close to the same).
Daniel, I also run a water / peltier cooled rig.
Maybe a "modified rig" thread is needed too............
GS
GS 2011-07-29
Guys,
I am thinking of buying August 2011 - Suggested Computer that Charles suggested, the high end with the i7-2600K processor. Do you have any exprerience with a reliable water cooling system. It would be great to run about 4.5GHz with temp lower than 60 Celcius degrees.
Thanks
SF
SF 2011-07-29
George, I can help you with picking out some parts and I have a few new ones here at the house. First what king of case are you working with and I conclude this will be cpu only. Guys are working right at the temp you quote on air (if ambient stays in the 70'sF) and with a good air HSF (Heatsink Fan) but I can see wanting to go water. Let me know your case type and if you want all gear inside the case and if you have decided if you want to run with a resivoir (not required but easier and better)I would suggest one of the cpu blocks from EK and a 3x120 (better known as a 360 radiator) from Black Ice.I have a brand new MCP 655 vario speed pump that is considered the industry standard I could let go and if you want a custom resivoir I know a man in Virgina that does some excellent work.I am in Tucson.Let me know about that computer case type and the other variables I mentioned.My i7-930 can maintain 62C @4.05GHz (82F ambient) but they run hotter than Sandy Bridge cpus.
GS
GS 2011-07-29
Daniel,
Temperatures about 50C would be more than welcomed with an i7-2600K running at 4.4GHz.This will be my goal, and that is for the case that will be doing renderings. In any other situation (from those i often use), i do not see high temperatures even in my current aircooled system (Quad Core Q9400 overclocked at 3.2GHz). So rendering is the most long time CPU demanding process (i do not use simulation much).
I haven't concluded yet with all specs of the system since i plan on buying it probably next month, depends on a project currently running.
I would go with the specs Charles suggested, except for the following:
  • Ram will be 16GB
  • Case will be full tower with some pre-arrangement for CPU liquid cooling modules and some extra fans.
For now i was just asking to get the general picture of water cooling. Although i have read a lot about water cooling i havent built one single system with water cooling modules.Since i am located in Europe, solutions from US manufacturers only can't be much of a help. I'll check though what you have suggested
When the time comes, i'll post some more detailed specs!
Cheers
SF
SF 2011-07-29
George, my experience is with the distributed computing programs from Stanford (in fact it is the protein folding program). Folding is by far the most stressful thing you can do with a PC.We run our rigs at 100% cpu load 24/7 (also the gpu if so inclined). I do not think the cpu load by SolidWorks will be anywhere near this extreme load situation. The case I have modded the most for water is the Antec 1200. This case is a bit skinny but that is really the only negative(besides it getting pretty dated). Picking the right case and picking the place for the radiator is very important. With the 1200 I located the power supply outside the case and put the radiator along the bottom.I cut out the bottom and put the case on wheels so it has good cold air intake. I also locate a resivoir in 2 or 3 of the hdd bays. You will have to decide on what case to use (I can help with this) not all cases are good choices for watercooling.Some people make some very difficult problems for themselves trying to watercool the wrong case,let me know. About the Intel 9400. I like this socket 775 cpu very much and I have 3 GigaByte EP45-UD3P motherboards just waiting for the right cpu.These are the best socket 775 cpu overclocking boards made,very durable. I notice you say your location is Europe,I can either direct you to a store or send you parts. What paticular country in Europe? my second home is Argau Switzerland.Ciao
GS
GS 2011-07-29
Daniel, thanks for the extra info.
I am located in Greece, you know that little country with the dept problem.
As soon as i have more info about when i will be ready to proceed with the purchase i'll post again with my configuration to discuss about it.
Cheers again.
SF
SF 2011-08-01
Hey All,
I have space restrictions that are making this build very difficult.  My case can not be more than 14.5 in tall.  I want to be able to overclock, but what i've been reading is that in a small case that will fit my space restrictions, it gets very hot, and thus difficult to overclock.  Do I need to use a water cooling system or can I get by without?  And would you have any recommendations on parts.  I'm still open to AMD or intel.  I'm leaning AMD for price reasons but the i72600K would be nice   I've found my restrictions to be heat in a small case...perhaps go with AMD and use the savings to get watercooling?  I'm still in the planning stages, so all options are currently open, except I need a case that's no taller than 14.5in.
SF
SF 2011-08-01
Mark,I will take a look at cases. My inital answer is Sandy Bridge (in all forms) have really knocked the prices down on i7-930's and X58 mobos (I prefer the ASUS P6X58D-Preminum). These are going used for 175.00 and cpu's in the 140-150 range, but you will be pushed more strongly to water cool that if you went Sandy Bridge (they clock higher on air). Let me look tomorrow and see if ther is even a suitable case. Is one of you requirements that all watercooling gear be fully inside the case?
Daniel
SF
SF 2011-08-01
Thanks for the thoughts.  the watercooling wouldn't need to be inside but it would be nice.  I've seen some mini-ITX builds that had the watercooling inside so I know it's certainly possible.  My worry is keeping things cool in such a small space,  If you watercool the GPU, CPU, how much heat would one still need to worry about from the northrbidge, RAM, etc?
Message was edited by: Mark CampbellBy the way i'm looking at an mATX mobo, not something smaller.  My other option as far as size restrictions go is laying it on its side.  What are the heat implications of running it on its side? what would I need to pay special attention to if I set it up this way?
SF
SF 2011-08-01
Mark, watercooling a miniITX is going to take the person doing it to be right there observing all the issues. Watercooling a mini-ITX case is something I strongly discourage. I have never been involved with a situation where RAM cooling and northbridge cooling are required. If you choose a properly heatsinked board it is not required. Northbridge and RAM watercooling is all for show and I strongly advise againt trying watercooling a mini-ITX case, some parts are just not designed to meet.
A cpu,gpu loop will need a full 360 size radiator. About laying the unit on its side. You want you loop to run resevoir>pump>radiatior>cpu>gpu>. You want to make full use of gravity to help keep your pump fed and aid in bleeding the system. These are prime considerations when constructing the loop.I am sure you can tell I feel certain restrictions develope when you want to go water.
SF
SF 2011-08-01
http://www.koolance.com/water-cooling/default.php?cPath=28_41
Any of those systems will water cool a mini ATX cased computer. Keep in mind, you will still need to buy the water blocks for the CPU and Video card, tubing, and nozzles (found at same site).
Kollance makes good water cooling products and are the bases of my systems I build.
SF
SF 2011-08-01
Chris,what I can say is have fun getting things to fit and you will not experience the same performance levels from these "kit" type watercooling products as you would picking the parts individualy.I am going to pass on any further comments concerning this build.
SF
SF 2011-08-01
I do not understand your comment "I am going to pass on any further comments concerning this build".
Your right on the performance of a "Kit" versus a "custom build".......you may note I stated I use Koolance as a base for my systems.
I mix and match, add peltier chip coolers, add primary and secondary heat exchangers...........I Too custom build my water cooling system (might explain why I can run my home AMD system at over 5 GHz). I have even gone as far as to experiment with N2O and CO2 cooling (not worth the effort IMHO)
But I don't get in a huff when someone suggests something different to me.......I have learned alot from other overclockers.....and have helped a few myself.
