Body-Move/Copy VBA Help needed (SelectByID2 with Face?)
I'm trying to apply the Move/Copy command on a single-bodied part (attached). I saved my commands with the macro recorder and am trying to edit the code to work generally.
What I'm having trouble with is selecting the face of the body. I've been fiddling with the code for ages trying various things, but nothing is working. Any help would be appreciated.
The code below is what I'm working on. It can be pasted into an empty module if neccessary. The first bit of code finds the largest face and I tried to squeeze this in to the Move/Copy code in every way I could imagine but nothing seeems to work. I'm not really sure what the best way forward is.
Private Sub AfterCreation()
    Dim swSelMgr As SldWorks.SelectionMgr
    Dim swBody As SldWorks.Body2
    Dim swFace As SldWorks.Face2
    Dim swEntity As SldWorks.Entity
    Dim swSelData As SldWorks.SelectData
    Dim swModExt As SldWorks.ModelDocExtension
    Dim Faces As Variant
    Dim Body As Variant
    Dim swPart As SldWorks.ModelDoc2
    Dim swComponent As SldWorks.Component2
    Set swModel = swApp.ActiveDoc
    Set swPart = swModel
    Set swModExt = swModel.Extension
    Set swSelMgr = swModel.SelectionManager
    ' Find face with largest surface area to align with front plane
    Dim LargestFaceArea As Double
    Dim CurrentFaceArea As Double
    Body = swPart.GetBodies2(swSolidBody, True)
    swModExt.SelectByID2 Body(0).Name, "SOLIDBODY", 0#, 0#, 0#, True, 0, Nothing, swSelectOptionDefault
    Set swBody = swSelMgr.GetSelectedObject6(1, -1)
     Set swFace = swBody.GetFirstFace
    Do While Not swFace Is Nothing
        CurrentFaceArea = swFace.GetArea
        If CurrentFaceArea > LargestFaceArea Then
            LargestFaceArea = CurrentFaceArea
            swFace.Select (0)
        End If
        Set swFace = swFace.GetNextFace
    Loop
    ' Apply Move/Copy feature
    Dim longstatus As Long
    Dim Component As Object
    Dim FeatureData As Object
    Dim varFeature As Object
    swPart.ClearSelection2 True
    swPart.Extension.SelectByID2 Body(0).Name, "SOLIDBODY", 0, 0, 0, False, 1, Nothing, 0
    Set varFeature = swPart.FeatureManager.InsertMoveCopyBody2(0, 0, 0, 0, 0, 0, 0, 0, 0, 0, False, 1)
    Set FeatureData = varFeature.GetDefinition()
    swPart.Extension.SelectByID2 "", "FACE", 0, 0.05, 0.008, False, 1, Nothing, 0 ' <---- MUST BE GENERALISED!!!
    swPart.Extension.SelectByID2 "Front Plane", "PLANE", 0, 0, 0, True, 1, Nothing, 0
    FeatureData.AddMate Nothing, 0, 0, 0, 0, longstatus
    varFeature.ModifyDefinition FeatureData, swPart, Component
End Sub
SolidworksApi macros
