I tried to do Batch checkin/Checkout. But its not processing all the files I selected. Its just process only that selected(where I right click). Am I doing anything wrong?
Case EdmCmdType.EdmCmd_Menu<br><br> If poCmd.mlCmdID = 1000 Then<br><br> poCmd.mlEdmRefreshFlags = 1<br> Dim edmVault As IEdmVault7 = TryCast(poCmd.mpoVault, IEdmVault7)<br> Dim edmBatchUnlock As IEdmBatchUnlock<br> edmBatchUnlock = edmVault.CreateUtility(EdmUtility.EdmUtil_BatchUnlock)<br> Dim i As Integer = 0<br> Dim selectedItems(i) As EdmSelItem<br><br> For Each AffectedFile As EdmCmdData In ppoData<br><br> Dim oFile As IEdmFile5 = edmVault.GetObject(EdmObjectType.EdmObject_File, AffectedFile.mlObjectID1)<br> selectedItems(i).mlDocID = AffectedFile.mlObjectID1<br> selectedItems(i).mlProjID = AffectedFile.mlObjectID3<br> MessageBox.Show(oFile.GetLocalPath(AffectedFile.mlObjectID3).ToString)<br> i = i + 1<br><br> Next<br><br> Try<br> edmBatchUnlock.AddSelection(edmVault, selectedItems)<br> edmBatchUnlock.CreateTree(0, 1)<br> edmBatchUnlock.UnlockFiles(0)<br> Catch ex As Exception<br> MessageBox.Show(ex.Message.ToString)<br> End Try<br><br> End If<br> End Select<span class="line-numbers-rows"><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span><span></span></span>Thanks
SolidworksApi/macros
On line 10 it appears that you have declared selectedItems as an Array of one item.
Best,
Amen
SOLIDWORKS PDM API Programming services
Best,
Amen
To add to what Mike is saying, you have that array of only one selected file and then you are using are adding that one selected file to the batch unlock utility.
The API help file example passes an array of EDMSelItem.
http://help.solidworks.com/2018/English/api/epdmapi/Batch_Unlock_Files_Example_VBNET.htm
