Hi All,
I am experiencing mesh problem. I have modelled an assembly (18 x 5m steel frame with some gussets and stiffeners and etc) and tried to mesh (curvature based) it but it stops at 98 percent which I believe is when SW tries to mesh volume (BTW i have no parts interfering)...I have tried to mesh each part and ended up successfully and took the minimum and maximum element sizes for all individual parts and applied on parent assembly but still experiencing the same. Mesh diagnostics shows the problem on the part where I have gathered all frame members so is not much helpful because I have many weldment profiles in it. I have also used Check entity and it says ''No invalid edges/faces found/No short edges found''
In the meantime, I have already used incompatible meshing option and it is OK but I am keen to mesh it without incompatible mesh.
I would appreciate any help
SolidworksSimulation
We do a lot of larger assemblies and run into similar situations. Many times just switching to standard mesh solves the problem and to get 'better' results we will run a finer mesh than we would for curvature based mesh.
are you meshing weldments with solids?
Yes I converted weldments in solids. It is really strange when I sort out say initially indicated part, the next one crops up in the next trial.
not sure what you mean here
If you are actually trying to model the weld bead - don't. You most certainly will not have the material properties correct and you aren't considering the HAZ in any event. Plus, you'd have to accurately model the weld and then it would only be an idealized geometry, i.e. perfection, and unrealistic. We do weldments all the time and have found that adding gussets and fishtails keep the analyst from 'chasing the wild stress monster'.
