API/Macro Batch Save as .SAT using Coordinate System
I have a macro that batch process save all configs as .SAT files using config name.
I need to use a coordinate system "Coordinate System1" (its set up to match autocad axis).
The problem is that the coordinate system is only being applied to first config that is saved and all other configs are not using "Coordinate System1".
How do I fix the below code to use "Coordinate System1". for all .SAT files that are exported?
Option Explicit
Dim Model As ModelDoc2
Dim LongStatus As Long
Sub main()
    Set Model = swApp.ActiveDoc
    Dim ConfigMgr As ConfigurationManager
    Dim C1a As Configuration
    Dim SelMgr As SelectionMgr
    Set SelMgr = Model.SelectionManager
    Set ConfigMgr = Model.ConfigurationManager
    ' Create a new configuration named Config1
    ' ConfigMgr.AddConfiguration "Config1", "Config1 comment", "alternateName", 1, "", "no description"
    ' Create a derived configuration called "Config1 Derived" whose parent configuration is "Config1"
    ' ConfigMgr.AddConfiguration "Config1 Derived", "Config1 Derived Comment", "Alternate Name", 1, "Config1", "no description"
    ' Show Config1 and make it the active configuration
    Model.Extension.SetUserPreferenceString swFileSaveAsCoordinateSystem, 0, "Coordinate System1"
    Model.ShowConfiguration2 ("Default")
    ' Get Config1
    Set C1a = Model.GetActiveConfiguration
    ' Determine if the active configuration is a derived configuration
    ' Debug.Print C1a.Name & " configuration derived? " & C1a.IsDerived
    ' Dim VChildren As Variant
    ' Determine the number of children configurations
    ' Debug.Print "  Number of children configurations: " & C1a.GetChildrenCount
    ' Get all of the children configurations
    ' VChildren = C1a.GetChildren
    ' Dim CDerived As Configuration
    ' Set CDerived = VChildren(0)
    ' Debug.Print CDerived.Name & " configuration derived? " & CDerived.IsDerived
    ' Dim CParent As Configuration
    ' Get the parent configuration of the derived configuration
    ' Set CParent = CDerived.GetParent
    ' Determine the number of configurations in this document
    ' Debug.Print "Number of configurations in part: " & swApp.GetConfigurationCount("C:\\Users\\Public\\Documents\\SOLIDWORKS\\SOLIDWORKS 2017\\tutorial\\api\\2012-sm.sldprt")
    Dim V As Variant
    ' Get the names of these configurations
    V = swApp.GetConfigurationNames(Model.GetPathName)
    Dim i As Long
    Debug.Print "Names of configurations in part:"
    Dim Folder As String
    Folder = InputBox("Please enter the path to the folder where you want to store the .SAT files", ".SAT Configuration Export", "E:\\BRC\\Library\\Casegood\\SAT")
    For i = 0 To UBound(V)
        ' Print the names of these configurations
        Debug.Print "  " & V(i)
        Model.ShowConfiguration2 (V(i))
        LongStatus = Model.SaveAs3(Folder & "\\" & V(i) & ".SAT", 0, 0)
    Next
End Sub
SolidworksApi/macros
