API Flat Pattern ModifyDefinition bugging out when executed from Assembly
The below macro is extracted from a larger macro, but I tried to extract the basic structure that is causing issues. The below code runs and it completes the desired actions (turning off merge faces from the flat pattern feature). The problem or buggy nature is that it after it completes, you cannot click on or highlight ANYTHING in the feature tree. It is stuck in a weird state what you can double click on a feature (or part) and expand it but you cannot highlight or right click it. Weirder, after it runs if you open a part (by right clicking in the model view) and close the part it allows you to select normally in the feature tree.
I am completely at a loss at what the problem is. I imagine it is maybe because I am editing the flat pattern feature when it is suppressed? Maybe because it is executing from a top level assembly? Any help is appreciated.
Sub main()
    Dim SwAssembly As SldWorks.AssemblyDoc
    Dim SwComponent As SldWorks.Component2
    Dim swConf As SldWorks.Configuration
    Dim boolstatus As Boolean
    Dim i As Long
    Dim swFlatPattern As SldWorks.FlatPatternFeatureData
    Dim swFeatMgr As SldWorks.FeatureManager
    Dim vChildComp As Variant
    Dim swChildComp As SldWorks.Component2
    Dim swFeat As SldWorks.Feature
    Set SwAssembly = swApp.ActiveDoc
    Set swConf = SwAssembly.GetActiveConfiguration
    Set SwComponent = swConf.GetRootComponent3(True)
    vChildComp = SwComponent.GetChildren
    For i = 0 To UBound(vChildComp)
        Set swChildComp = vChildComp(i)
        Set swModel = swChildComp.GetModelDoc2
        Set swFeatMgr = swModel.FeatureManager
        Set swFeat = swModel.FirstFeature
        While Not swFeat Is Nothing
            If swFeat.GetTypeName2() = "FlatPattern" Then
                Set swFlatPattern = swFeat.GetDefinition
                swFlatPattern.AccessSelections swModel, Nothing
                swFlatPattern.MergeFace = False 'Turns off Merge Face Option in flat pattern feature
                swFeat.ModifyDefinition swFlatPattern, swModel, Nothing
                boolstatus = swFeatMgr.EditRollback(swMoveRollbackBarToAfterFeature, swFeat.Name)  'Required or assembly says it is in a roll back state.
            End If
            Set swFeat = swFeat.GetNextFeature
        Wend
    Next i
End Sub
SolidworksApi macros
