[API] Change Boss Feature's depth
I have created a sketch ("Sketch1") and via extruded it via 'Extruded Boss' (to "Boss") to 2mm.
Now I want to change the depth of this extrusion in Visual Basic.
I already have the following code:
<p>Dim baseDisk, metalDisk As SldWorks.PartDoc</p><p>metalDisk = openPart("MetalDisk.sldprt")</p>
How can i change the depth of the feature?
Thank you very much!
SolidworksApi macros
Answers 12
KR
KR 2011-10-14 Best Answer
Hi Anne,
You need to access the IFeature interface of the extrude feature and then use IFeature::GetDefinition to access the IExtrudeFeatureData2 interface, which allows access to the properties of an extrude feature.  In particular you want IExtrudeFeatureData2::SetDepth.  Once you have changed the dept you need to use IFeature::ModifyDefinition to save the changes to the feature.
Try this.  Create a new part and make one boss extrude feature with a depth of 50mm.  Then run this macro.  It should be changed to 100mm.  The feature name must be "Boss-Extrude1".
Dim swPart As SldWorks.PartDoc
Dim swFeat As SldWorks.Feature
Dim swExtrudeFeatData As SldWorks.ExtrudeFeatureData2
Sub main()
    Set swModel = swApp.ActiveDoc
    Set swPart = swModel
    Set swFeat = swPart.FeatureByName("Boss-Extrude1")
    Set swExtrudeFeatData = swFeat.GetDefinition
    swExtrudeFeatData.SetDepth True, 0.1
    swFeat.ModifyDefinition swExtrudeFeatData, swModel, Nothing
End Sub
Keith
Video Tutorials for the SolidWorks API
KR
KR 2011-10-14
Just some clarifying comments...
Technically, you don't need to use AccessSelections to change the depth parameter.  AccessSelections, which puts the part in a rollback state at that feature, is only necessary when you need to access the entities used to create the feature.  To work with any other feature parameters it is sufficient to use IFeature::GetDefinition and IFeature::ModifyDefinition.  Notice that my code above successfully modifies the feature definition but does not use AccessSelections.
Also, note that if you use AccessSelections and do NOT make any changes (and therefore do not use IFeature::ModifyDefinition) then you still need to use ReleaseSelections to remove the part from its rollback state.
Keith
CADSharp LLC
WM
WM 2011-10-14
Keith,
I typically use the IDimension::SetUserValueIn2 method to change dimension values like changing extrusion depth. What are the advantages of doing it your way?
SF
SF 2011-10-14
Oh .. that is SW help .. not sure why they recommend to change feature depth that way.
Yes I vaguely remember there are few other things also on feature data which can be changed without accessing selections.
KR
KR 2011-10-15
Hey Wayne,
How are you accessing IDimension?
If you already have easy access to IDimension and all you need to do are change the depth, then IDimension::SetUserValueIn2 would be fastest.  Otherwise, using IFeature would definitely be preferable since it is quicker to access (IMO) and gives you full control over the feature.
And actually, if you are going control the parameter via dimensions and not via the feature itself, you might as well just use IModelDoc2::Parameter.  That might be even faster than IDimension::SetUserValueIn2.
Keith
CADSharp LLC
SF
SF 2011-10-15
Thank you all very much for your quick response!
Unfortunately it doesn't work yet. I get the following error:
<p>System.Runtime.InteropServices.COMException was unhandled</p><p>  ErrorCode=-2147417851</p><p>  Message=De server heeft een uitzondering geretourneerd. (Uitzondering van HRESULT: 0x80010105 (RPC_E_SERVERFAULT))</p><p>  Source=Interop.SldWorks</p><p>  StackTrace:</p><p>       bij SldWorks.IFeature.ModifyDefinition(Object Data, Object TopDoc, Object Component)</p><p>       bij Creating_Assemblies.MainForm.buildAssembly(String configName, Int32 noDiskPairs, AssemblyDoc swAssembly, PartDoc baseDisk, PartDoc metalDisk, PartDoc fibreDisk) in ***\MainForm.vb:regel 177</p><p>       bij Creating_Assemblies.MainForm.GenerateButton_Click(Object sender, EventArgs e) in ***\MainForm.vb:regel 58</p><p>       bij System.Windows.Forms.Control.OnClick(EventArgs e)</p><p>       bij System.Windows.Forms.Button.OnClick(EventArgs e)</p><p>       bij System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)</p><p>       bij System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)</p><p>       bij System.Windows.Forms.Control.WndProc(Message& m)</p><p>       bij System.Windows.Forms.ButtonBase.WndProc(Message& m)</p><p>       bij System.Windows.Forms.Button.WndProc(Message& m)</p><p>       bij System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)</p><p>       bij System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)</p><p>       bij System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)</p><p>       bij System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)</p><p>       bij System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)</p><p>       bij System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)</p><p>       bij System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)</p><p>       bij System.Windows.Forms.Application.Run(ApplicationContext context)</p><p>       bij Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun()</p><p>       bij Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()</p><p>       bij Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[] commandLine)</p><p>       bij Creating_Assemblies.My.MyApplication.Main(String[] Args) in 17d14f5c-a337-4978-8281-53493378c1071.vb:regel 81</p><p>       bij System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)</p><p>       bij System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)</p><p>       bij Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()</p><p>       bij System.Threading.ThreadHelper.ThreadStart_Context(Object state)</p><p>       bij System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)</p><p>       bij System.Threading.ThreadHelper.ThreadStart()</p><p>  InnerException: </p>
for the ModifityDefinition method...
Do you know how I can solve this exception?
This is the code:
' get Part
Dim baseDisk, metalDisk As SldWorks.PartDoc<br>metalDisk = openPart(<span style="color: red;">"MetalDisk.sldprt"</span>)
' More code...
' change dimensions
        ' Get height dimension metalpart and change
        swFeat = metalDisk.FeatureByName("Base-Extrude")
        swExtrudeFeatData.SetDepth(True, diskMetalkHeight)
        swFeat.ModifyDefinition(swExtrudeFeatData, swModel, Nothing)
        swExtrudeFeatData.ReleaseSelectionAccess()
KR
KR 2011-10-15
Anne,
You have declared swFeat and swExtrudeFeatData twice.  Aren't you getting an error for duplicate variable declaration?
Also, since you're using IFeature::ModifyDefinition you do not need to use IExtrudeFeatureData2::ReleaseSelectionAccess, so remove that last line.
See if this makes any difference.  If not, can you post your entire module or class and state again what line is failing?  Thanks.
Keith
CADSharp LLC
SF
SF 2011-10-15
No, that didn't help
This is the full source-code:
Problem is at this line:
CODE:
Public Class MainForm
    ' global variables
    Dim swApp As SldWorks.SldWorks          ' connection to the SolidWorks API
    Dim configNames As String()             ' array with configuration names
    Private Sub ExitButton_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ExitButton.Click
        Close()
    End Sub
    Private Sub GenerateButton_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles GenerateButton.Click
        Dim configName As String    ' name of the configuration
        Dim noDiskPairs As Integer  ' number of disk pairs in the assembly
        ' connect to SolidWorks
        swApp = New SldWorks.SldWorks()
        If (swApp Is Nothing) Then
            MsgBox("Cannot connect to SolidWorks", MsgBoxStyle.Exclamation)
            Exit Sub
        End If
        ' find the number of disk-pairs
        If (Integer.TryParse(PairsTextBox.Text, noDiskPairs) = False) Then
            MsgBox("Invalid number of pairs", MsgBoxStyle.Exclamation)
            Exit Sub
        Else
            If (noDiskPairs < 1) Or (noDiskPairs > 12) Then
                MsgBox(PairsTextBox.Text & " outside valid range [1..12]", _
                noDiskPairs = 0
                Exit Sub
            End If
        End If
        ' get the name of the configuration
        configName = CluchTypeComboBox.SelectedItem()
        ' create a new assembly
        Dim swAssembly As SldWorks.AssemblyDoc
        swAssembly = newAssembly()
        If (swAssembly Is Nothing) Then
            MsgBox("Failed to create new assembly", MsgBoxStyle.Exclamation)
            Exit Sub
        End If
        ' load the three parts
        Dim baseDisk, metalDisk, fibreDisk As SldWorks.PartDoc
        baseDisk = openPart("BaseDisk.sldprt")
        fibreDisk = openPart("FibreDisk.sldprt")
        If (baseDisk Is Nothing) Or (metalDisk Is Nothing) Or (fibreDisk Is Nothing) Then
            MsgBox("Failed to open part BaseDisk, MetalDisk or FibreDisk", _
            Exit Sub
        End If
        ' put it together
        buildAssembly(configName, noDiskPairs, swAssembly, baseDisk, metalDisk, fibreDisk)
    End Sub
    Private Sub MainForm_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        ' create the list of clutch configurations
        configNames = {"Standard", "High", "Racing"}
        ' enter the names in the typelist ComboBox
        CluchTypeComboBox.Items.AddRange(configNames)
        ' watch the index, first one is 0
        CluchTypeComboBox.SelectedIndex = 0
        ' deafult no disk pairs
        PairsTextBox.Text = "4"
    End Sub
    Private Function getModelSimpleName(ByRef swDoc As SldWorks.ModelDoc2) As String
        ' This function dissambles the name of the assembly from its full path name
        ' You'll use AssemblyName when mating the component with the assembly
        ' an array with the separated strings
        Dim strArray As String()
        ' get title of document
        Dim documentTitle As String = swDoc.GetTitle()
        ' split the title into two strings using the period (.) as the delimiter
        strArray = Split(documentTitle, ".")
        ' return first name part
        Return strArray(0)
    End Function
    Function flipZdirection() As SldWorks.MathTransform
        ' This method returns a transformation matrix that flips the Z-axis by a Y-axis rotation
        Dim swXform As SldWorks.MathTransform
        Dim rotCenter As SldWorks.MathPoint
        Dim rotAxis As SldWorks.MathVector
        Dim angle As Double
        rotCenter = swApp.IGetMathUtility.CreatePoint({0.0#, 0.0#, 0.0#})
        rotAxis = swApp.IGetMathUtility.CreateVector({0.0#, 1.0#, 0.0#})
        angle = Math.PI
        swXform = swApp.IGetMathUtility.CreateTransformRotateAxis(rotCenter, rotAxis, angle)   ' create unit transform
        Return swXform
    End Function
    Private Function newAssembly() As SldWorks.AssemblyDoc
        Dim assyTemplate As String
        Dim swAssy As SldWorks.AssemblyDoc
        ' get template name
        ' bedenk het maar! dit kost wat clicks door de API help
        assyTemplate = swApp.GetUserPreferenceStringValue( _
        SwConst.swUserPreferenceStringValue_e.swDefaultTemplateAssembly)
        If (assyTemplate = "") Then
            MsgBox("Please define a Default Assembly Template " _
            & "before running this program", _
            Return Nothing
        End If
        ' value = instance.INewDocument2(TemplateName, PaperSize, Width, Height)
        swAssy = swApp.INewDocument2(assyTemplate, 0, 0.0#, 0.0#)
        Return swAssy
    End Function
    Private Function openPart(ByVal partName As String) As SldWorks.PartDoc
        Dim errors, warnings As Integer
        ' get pathname to parts
        Dim path As String
        path = Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments) _
        & "\SWparts"
        If (Not System.IO.Directory.Exists(path)) Then
            MsgBox("Please put the part templates in " & vbCrLf & _
            path & vbCrLf & "before running this program", _
            Return Nothing
        End If
        swPart = swApp.OpenDoc6(path & "\" & partName, _
        SwConst.swDocumentTypes_e.swDocPART, _
        SwConst.swOpenDocOptions_e.swOpenDocOptions_LoadModel, _
        "", _
        errors, _
        warnings)
        Return swPart
    End Function
    Private Sub buildAssembly(ByVal configName As String,
                            ByVal noDiskPairs As Integer,
                            ByVal swAssembly As SldWorks.AssemblyDoc,
                            ByVal baseDisk As SldWorks.PartDoc,
                            ByVal metalDisk As SldWorks.PartDoc,
                            ByVal fibreDisk As SldWorks.PartDoc)
        Dim diskMetalkHeight = 100
        Dim diskFibreHeight = 100
        If (configName = "Standaard") Then
            diskMetalkHeight = 1.0
            diskFibreHeight = 2.0
        ElseIf (configName = "High") Then
            diskMetalkHeight = 1.2
            diskFibreHeight = 2.4
        ElseIf (configName = "Racing") Then
            diskMetalkHeight = 1.6
            diskFibreHeight = 3.0
        End If
        diskMetalkHeight = diskMetalkHeight * 10
        diskFibreHeight = diskFibreHeight * 10
        ' change dimensions
        ' Get height dimension fibrepart and change
        swFeat = fibreDisk.FeatureByName("Base")
        Dim errorState As Integer
        Dim component1, component2 As SldWorks.Component2
        swApp.ActivateDoc2(swAssembly.GetTitle(), False, errorState)
        ' add parts, first base + metal
        component1 = swAssembly.AddComponent5(baseDisk.GetPathName(), 0, "", False,
        "Default", 0.0#, 0.0#, 0.0#)
        component2 = swAssembly.AddComponent5(metalDisk.GetPathName(), 0, "", False,
        component2.ReferencedConfiguration = configName
        ' flip the base part in z-direction to prevent mate problems
        component1.Transform2 = flipZdirection()
        mateDisksByID(swAssembly, component1, component2)
        ' add pairs, fibre + metal
        For index = 1 To noDiskPairs
            ' mate previous metal to new fibre
            component1 = component2
            component2 = swAssembly.AddComponent5(fibreDisk.GetPathName(), 0, "", False,
            ' mate new fibre to new metal
        Next
        ' rebuild etc.
        swAssembly.ClearSelection2(True)
        swAssembly.EnableAssemblyRebuild = True
        swAssembly.ForceRebuild2(True)
    End Sub
    Private Sub mateDisksByID(ByVal swAssembly As SldWorks.AssemblyDoc, ByVal component1 As SldWorks.Component2, ByVal component2 As SldWorks.Component2)
        Dim boolStatus As Boolean
        ' get reference to assembly's extended function set
        Dim swExt As SldWorks.ModelDocExtension
        swExt = swApp.ActiveDoc().Extension
        Dim assyName, compName1, compName2 As String
        assyName = getModelSimpleName(swAssembly)
        compName1 = component1.Name2
        compName2 = component2.Name2
        ' add coincident mate on axes of rotation
        boolStatus = swExt.SelectByID2("Axis1@" & compName1 & "@" & assyName, "AXIS",
                                        0, 0, 0, False, 1, Nothing,
                                        SwConst.swSelectOption_e.swSelectOptionDefault)
        boolStatus = swExt.SelectByID2("Axis1@" & compName2 & "@" & assyName, "AXIS",
                                        0.0#, 0.0#, 0.0#, True, 1, Nothing,
        swAssembly.AddMate3(SwConst.swMateType_e.swMateCOINCIDENT,
                                        SwConst.swMateAlign_e.swMateAlignALIGNED,
                                        False, 0.0#, 0.0#, 0.0#, 1.0#, 1.0#, 0.0#, 0.0#, 0.0#,
                                        False, errorState)
        ' add coincident mate of front- and back surface
        boolStatus = swExt.SelectByID2("RefPlane2@" & compName1 & "@" & assyName, "PLANE",
        boolStatus = swExt.SelectByID2("RefPlane1@" & compName2 & "@" & assyName, "PLANE",
                                        SwConst.swMateAlign_e.swAlignAGAINST,
                                        False, errorState)
    End Sub
    Private Sub Moment(ByVal swAssembly As SldWorks.AssemblyDoc)
    End Sub
    Private Sub Diepte(ByVal swAssembly As SldWorks.AssemblyDoc)
    End Sub
    Private Sub Volume(ByVal swAssembly As SldWorks.AssemblyDoc)
    End Sub
    Private Sub Gewicht(ByVal swAssembly As SldWorks.AssemblyDoc)
        Dim gewicht = swAssembly.GetLightWeightComponentCount
        LabelGewicht.Text = gewicht
    End Sub
End Class
Thank you!
KR
KR 2011-10-15
Anne,
Can you verify that a part is the active document when that problematic code is being run?  Because if you are in an assembly then the third argument of IFeature::GetDefinition needs to be the component. (See the documentation for more remarks.)
Have you tested the feature modification code in its own separate macro?  You should make sure it is working outside of your current project before you include it.
Keith
CADSharp LLC
SF
SF 2011-10-16
When I try the code u gave me earlier, it works in a macro for one part.
This code compiles without errors, and it works!
For those with similar problems: When I opened multiple parts the activeDoc was wrong, so when you
want to change something from part x.sldpt, you must run
<p>swModel = swApp.ActivateDoc2("x", True, errors)</p>
first to set part x as the active part.
The complete solution:
<p> ' change dimensions</p><p>        Dim swModel As SldWorks.ModelDoc2</p><p>        swModel = swApp.ActiveDoc</p><p>        Dim swFeat As SldWorks.Feature</p><p>        Dim swExtrudeFeatData As SldWorks.ExtrudeFeatureData2</p><p>        Dim errors As Long</p><p></p><p></p><p>        ' Get height dimension metalpart and change</p><p>        swModel = swApp.ActivateDoc2("MetalDisk", True, errors)</p><p>        metalDisk = swModel</p><p>        swFeat = metalDisk.FeatureByName("Base-Extrude")</p><p>        swExtrudeFeatData = swFeat.GetDefinition</p><p>        swExtrudeFeatData.SetDepth(True, diskMetalkHeight)</p><p>        swFeat.ModifyDefinition(swExtrudeFeatData, swModel, Nothing)</p><p></p><p></p><p>        ' Get height dimension fibrepart and change</p><p>        swModel = swApp.ActivateDoc2("FibreDisk", True, errors)</p><p>        fibreDisk = swModel</p><p>        swFeat = fibreDisk.FeatureByName("Base")</p><p>        swExtrudeFeatData = swFeat.GetDefinition</p><p>        swExtrudeFeatData.SetDepth(True, diskFibreHeight)</p><p>        swFeat.ModifyDefinition(swExtrudeFeatData, swModel, Nothing)</p>
Thank you very much for your help!
KR
KR 2011-10-17
Hi Anne,
That is good to hear.  If your original question was answered then please mark the thread as 'answered'.
Thanks,
CADSharp LLC
