Hi all,
I'm running SW Premium 2015 x64 SP 3.0 and I need a macro to modify the sketch used in a chain pattern.
I'm not very experienced in writing macros for SolidWorks but I've managed to put this together by editing various forum posts.
See code below (some irrelevant parts have been removed and I've censored the part/assembly names)
When I try to run it I get the error "User-defined type not defined" at the line in bold below.
After doing some digging it would seem that ChainPatternFeatureData is not available in SW 2015?
Is there any way I can do this in SW 2015?
Thanks!
Chris
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Sub main()
Set Part = swApp.ActiveDoc
Dim myModelView As Object
Set myModelView = Part.ActiveView
myModelView.FrameState = swWindowState_e.swWindowMaximized
Part.ClearSelection2 True
boolstatus = Part.Extension.SelectByID2("XXXX@XXXX-1@XXXX/XXXX-1@XXXX", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
Dim swSelMgr As SldWorks.SelectionMgr
Set swSelMgr = Part.SelectionManager
Dim swFeature As SldWorks.Feature
Set swFeature = swSelMgr.GetSelectedObject6(1, -1)
Dim swSketch As SldWorks.Sketch
Set swSketch = swFeature.GetSpecificFeature2
boolstatus = Part.Extension.SelectByID2("XXXX@XXXX", "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0)
Dim swChainPatt As SldWorks.ChainPatternFeatureData
Set swChainPatt = swFeature.GetDefinition
swChainPatt.AccessSelections Part, Nothing
swChainPatt.Sketch = swSketch
boolstatus = swFeature.ModifyDefinition(swChainPatt, Part, Nothing)
End sub
SolidworksApi macros
