2018 SP0.1 x64
In an assembly I cannot INSERT COMPONENT>NEW PART, all I get after selecting a template is a green check mark under the cursor.
However, I can insert new assembly into the assembly and it becomes active in the tree.
SolidworksAssemblies
You need to select a plane/face/planar surface to define the front plane of the new part.
no, you can also select an empty space in the graphics area. if this is done, the new part is located to the assembly origin, and fixed.
Yes that's correct.
I always select a plane to define the orientation of my inserted new parts and hence suggested that only.
That is how I though I did it in the past, I don't recall every doing like Mr Gupta suggested, however his method did work.
A side note, I tried to record video of this functionality and the video recorder did not work
