Hi everyone! I’m exploring a method to vary the stiffness and damping properties of a spring/dashpots system dynamically at each iteration, based on parameters such as the shaft speed (omega) and the node’s position (X and Z). My approach involves using sensors to capture the node’s location. Do you think this can be implemented using the UAMP subroutine, or would you suggest an alternative method? Thank you in advance!
