Vibration is calculated by ABAQUS.
Frequency→Steadty state Dynamics→Modal dynamic
I am proceeding with the calculation in the step of, but the calculation does not progress in the step of Modal dynamic
(If you check the sta file, it has not been written since the end of frequency response analysis)
I'm guessing it's probably because the model is large, but what could be the cause of the slowdown?
The following model information
Model freedom: 1.18 million
Output points: 183 nodes, 10000 increments (because I want to check 1 second each 0.0001 seconds)
Field output variables: A, AR, COOR, U, UR, V, VR
History output variables: GA, GU, GV, various energies
I would like to analyze under the above conditions. Is there a workaround?
Thank you for your cooperation.
