Steady-State Analysis Terminating Early at 1250Hz Instead of 2000Hz Without Clear Error Messages
Hello everyone,
I'm currently working on a direct steady-state analysis using Abaqus standard, and I've encountered an issue where my analysis unexpectedly stops at 1250 Hz, though it's supposed to run up to 2000 Hz. The log file indicates that the analysis exited with errors, but the data and msg files don't show any specific error messages. Additionally, the results in the data and odb files only cover up to 1250 Hz.
I am wondering if anyone has experienced similar issues or might suggest additional diagnostics or settings to check that could influence this behavior?
Thank you in advance for your help and suggestions!
