Hi, everyone
I have project about the gas flow mode on the low-pressure equipment, I encounter some difficulties about gas expansion on the low-pressure device.
The gas (2l/min) will inject into equipment, Under normal temperature and pressure. the pressure and temperature inside the equipment are 5 kPa and 1000K, respectively.
The question is ...When i set the boundary conditions (inlet flow rate), which one should i set: 2l/min with normal temperature and pressure or the flow rate after EXPANSION with 5kPa and 1000K?
another question is how should i set the initial condition when i use the guide?
Thank you!!
SOLIDWORKS
