Hello Simpack community,
I'm trying to generate my own rotorblade using the rotorblade generator feature on SIMPACK, while taking in reference the NREL-MW Blade structural properties. I assume that the Basic blade model in the example of the 5-MW wind turbine is modelled taking in reference the NREL-5MW documentation. Although there seems to be some approximation and differences with the NREL 5-MW model in the structural properties such as number of nodes, mass/length, flap/edge stiffness etc.
I tried to use the same number of nodes and assign the same structural properties as the document on my SIMPACK blade, the only confusion I have is the chord length. How to calculate or assign the correct chord length on each element after increasing the number of station id(nodes) in the Blade input files?
Appreciate your help on this matter.
Regards,
Muffaddal Juzer.
