Problem Description Model A : no loading error/ Both Time Integral (online) and Time Integral (offline) run without errors. Model B : When the file is opened, Simpack shows:[ERROR: Could not load shared library...searching for 'uforce247wrap_setup'] Time Integral (offline) runs normally. Time Integral (online) stops immediately with [FATAL: Setup (task 1) of Force Element \\\$F_AeroDynV330_T2: Evaluation failed with error code 29902. FATAL: MBS element pre-processing failed: ierr = 29902 ERROR: The Force Element of type 247 with name \\\$F_AeroDynV330_T2 is not available for win64. Therefore the element cannot be edited and the solver will reject this model. Absolute Body positions were computed neglecting the unavailable element. Please compile and link the respective User Routine for this platform.]
I have been troubleshooting this for a full week but have not found a solution. If anyone has faced a similar uforce247wrap_setup or Force Element 247 issue in Simpack 2024x.6 / OpenFAST 3.3 where only certain models fail, I’d appreciate your insights. If further testing is required, please let me know what information I should provide. |
