Severe contact penetration after element deletion (C3D10M, J-C Damage) in Explicit quasi-static compression
I am currently running a quasi-static compression simulation of a TPMS (Triply Periodic Minimal Surface) lattice structure using Abaqus/Explicit, and I am encountering a severe mesh penetration issue immediately after element deletion is triggered.
Setup:
  • Mesh: C3D10M, 0.2 mm, distortion control ON,element deletion ON.
  • Material: J-C plasticity + J-C damage initiation + displacement-based evolution (0.02 mm).
  • Contact: General contact, hard normal, friction 0.15.
Issue:
  • ①: Top layer elements deleted (STATUS=0).
  • ②: The rigid surface continued to press down, and then the grid model penetrated the rigid surface.
  • ③:I attempted to conduct the test using a cylinder, but the same phenomenon of penetration occurred.
Thanks!
