Sealing problem
I'm new to Abaqus. I would be really appreciated that someone can share idea on how to simulate a water leakage problem:
A module with a probe of 6mm in diameter. The probe is sealed against water leakage with a radial seal ring. I suppose, firstly, I've to derive a step on the contact between the seal ring & then anothere step to apply the water pressure. However, how can I determine which element/surface subjected to the water pressure (1.5bar) as the seal ring in contact with the probe is deformed?
