Hi to all,
I'm trying to remove initial overclosures contact giving initialization assignments in general contact ut I always have this error:
The volume of 10010 elements is zero, small, or negative. Check coordinates or node numbering, or modify the mesh seed. In the case of a tetrahedron this error may indicate that all nodes are located very nearly in a plane. The elements have been identified in element set ErrElemVolSmallNegZero.
Any ideas to solve this issue?
Thanks
