Hi Good Morning to every one, i am running a model of fan, i am not using cyclic symmetry, i want to see full rotation of fan. Please let me know if any one has idea what is wrong i am doing. The problem what i did is as follows
1) I have done modeling of fan, material,density,section, assignment, assembly are correct i think.
In assembly i have created 2 RPs to define axis of rotation, i have given Constrains as Copuling of RPs and inner boundary nodes of fan.
2) I have 4 steps,Dynamic explicits, They are Initial,Rotation, Reduced Rotation, Zero velocity.
4) Boundary conditions
BC1,step-Initial,Velocity/angular velocity, Applied on RP1 and RP2, All selected as Zero except VR1 (not selected since i need rotation about X axis)
BC2, Step-Rotation, Velocity/Angular velocity, On RP1 & RP2, Selected only VR1-31.4 rad/sec
BC2,Step-Reduced Rotation, Velocity/Angular velcity, On RP1 & RP2, Selected VR1-6.28 rad/sec
BC4, step-Zero Velcity, Velocity/Angular velocity, On RP1 & RP2,selected VR1-0 rad/sec
5) Loads
Body force in terms of inertia, step-Rotation, Given CM1, CM2, CM3
Body Force, step-Reduced Rotation, Given CM1, CM2,CM3.
Results i need- want to see stress in fan blades due to body force and rotations.
Error i am getting once i submit the Job is " 2 nodes have dof on which velocity/displ/accn/base motion etc. constraints are specified simultaneously. The nodes have been identified in node set ErrNodeBCReduntantDof."
How can i see which 2 nodes are having problem?
Please correct or guide me how to proceed to see the results.
