Probing Specific Points Consistently
I have an assembly with multiple parts subjected to mechanical loading: essentially multiple parts that make up a loading structure and a test panel. I need to probe values at a specific set of points on the top and bottom surfaces of the test panel (modeled as a shell). These locations are the locations of strain gages installed on those surfaces IRL.
What is the best way to consistently probe a set of ~9 points on each of the surfaces?
I created a partition on the part, in the part module, (hoping to simply use the intersection points of said partition to select the points of interest in the visualization page) but the partition lines aren't showing up in the visualization. I tried going to Options>Common and selecting all of the visible edge options, but it either hides everything (only showing the contour) or shows everything (the mesh, which obscures the partition I created).
Any help would be greatly appreciated.
