Please help
I am using 6.12-3 abaqus version and facing this problem. Please help me how to remove this error..
The executable pre.exe aborted with system error code 1073741819. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
I read comments that ....A standard analysis aborts with error code: 1073741819 when run on an Intel I7 4th generation processor (Haswell) A workaround is to rename the mkl_avx2.dll in the C:\\SIMULIA\\Abaqus\\6.13-x\\code\\bin directory to mkl_avx2.dll.11.0.0.1
In my abaqus version I have mkl_avx.dll not mkl_avx2.dll
cheers,
Hina
