Goal
Predict HCF fatigue life using Stress-Life (S–N) in Durability, reading stresses from a Static analysis of a press (punch/die) setup.
Environment
3DEXPERIENCE (SIMULIA Structural + fe-safe Durability, EDU license) / Solid elements / Units: MPa, mm
Model & BCs (current)
- Die/Base: bottom face Clamp
- Punch: Applied Translation (Y) on the top face (prescribed displacement)
- Sheet: ideally free (controlled by contact); to avoid drift, only two tiny faces: X=0 at one, Z=0 at another ( Y is free )
- Contacts: punch–sheet and sheet–die with friction
Durability (S–N) settings
- Life regime: Finite life
- Algorithm: von Mises (stress-based)
- Mean stress correction: Goodman ( UTS provided)
- Frequency domain: von Mises / None
- Override material contains S–N curve (R=−1), endurance limit, UTS
- Issue 2 – Warning
Step 'Static Step1' contains non-linear geometry. Fatigue results for solid elements will be incorrect unless material orientations have been defined for those elements.- It appears when Geometric nonlinearity (NLGEOM) is ON in the Static step.
- Q2) With stress-based S–N (signed von Mises), do I still need to define Material Orientation for solid elements when NLGEOM is ON?
- (a) For elastic HCF, is turning NLGEOM OFF the recommended approach?
- (b) If NLGEOM is required, where and how should I define the orientation (Cartesian vs Cylindrical) for solids in 3DEXPERIENCE?
