Hello everyone,
I am using Isight 2022 and need to multiply the simulated force output of an Abaqus model by a factor (e.g., 4) to use with the Data Matching feature. (Just an example of a task I need to perform)
I simulate only a quarter of a geometry and need to adjust the output accordingly. Although I defined and modified the column using a Jython script, the Data Matching component shows this column as empty.
Could anyone provide insights on the correct procedure to operate on Abaqus Output History data in Isight (such as simple multiplication of a column data) and pass this modified column to the Data Matching Component? Any examples or tips would be greatly appreciated.
Thank you
