The question is related to the hardware capabilities for meshing and running the simulation after setting it up in the Fluid Scenario Creation App: it takes a while to create mesh and subsequently, perform the model and scenario checks before starting the simulation. If everything is set up correctly, there is a possibility to run the simulation on cloud (with 4 cores by default). Is there any possibility to do the same for creating a mesh and checking the model&scenario? The only way around it I saw in the mesh settings (Optional: Specify a Remote host to generate the mesh on a preconfigured remote host computer.), but for this, as far as I understand, I need to set up a remote host (cluster) locally.
