Connecting Rod-Piston Simulation with Connectors | Mechanical Optimization 🔩
In this analysis, we explore the optimization of mechanical assemblies by simulating a connecting rod-piston system under dynamic load. The focus is on using "Pin" and "Bolt" connectors, which are essential for realistic modeling of mechanical interactions.
📌 Objectives:
✅ Apply AISI 1020 material for accurate simulation,
✅ Define and configure mechanical connectors to replace rigid joints,
✅ Integrate preloads and friction coefficients for enhanced realism,
✅ Analyze stresses and deformations to optimize the design.
🚀 Why use connectors?
🔹 Precise distribution of forces and loads,
🔹 Realistic simulation of pivot movements,
🔹 Optimized meshing for more efficient calculations.
🔎 Results & Impact
The integration of connectors has improved accuracy while reducing computation time, providing a more realistic approach applicable to the automotive, aerospace, and general mechanical industries.
💡 A step forward in advanced simulation for robust and reliable design!
ABBK PhysicsWorks | SOLIDWORKS & 3DEXPERIENCE Tunisia & West Africa | Dassault Systèmes
#MechanicalSimulation #ConnectingRodPiston #MechanicalOptimization #PinConnectors #BoltConnectors #AISI1020 #DynamicLoad #3DModeling #AdvancedDesign #StructuralAnalysis #SOLIDWORKS #3DEXPERIENCE #Engineering #DesignOptimization #AutomotiveIndustry #AerospaceIndustry #AdvancedSimulation #RobustDesign #MechanicalAnalysis
